so recently I asked a question about a clicking noise coming from the radiator. Well finally the cancer has been cured! It started with a strange clicking coming from what I thought was the canister at the top of the radiator. A few days later , our idiot light came on. Diagnosis was a cracked connector pipe and a cracked thermostat cover. (I personally examined both). PCR ran fine for 2 days when symptoms started again. This time the leak was from the solenoids that mix your heat. Part was replaced and all is fine!
Radiator hoses and heater Solenoids
Getting ready to have mix valve assembly installed on the Light Ice Blue, but no clicking noise.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
Is the part you're replacing Ford Part # 2R8Z-18495-AA. Last time I replaced this was after my trip to your home after Wisconsin Thunder. It was simply called "Valve Assembly". I called it the Hot water Coolant valve.Originally posted by 4LOWBIRDS+7 View PostGetting ready to have mix valve assembly installed on the Light Ice Blue, but no clicking noise.sigpic
Yes that is the one. I am using a Motorcraft part from EBay, $99.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
