I took my bird to the shop to have the cross braces retorqued and to get an inspection of the suspension. The mechanic did find "several" cross brace bolts to be under torqued, but not loose. Good find and good heads up from this forum
Now for the rest of the story... Seems all the rubber boots on the steering and suspension joints are dry rotted from age, some have already torn and/or split. The shop quoted new rear control arms with bushings installed at $260.00 each for uppers and $400.00 each for lowers. Seems high to me. I also questioned if the bushings can be changed? The mechanic said yes if the parts are available. So I am now searching for control arm bushings. Any other birders have had experience with this? If so are the bushings available?
