Never understood why such a tiny space needed dual climate control. If you and your passenger can’t agree on temperature, you may have larger problems to deal with.
Heater controls.
Ok. A solution has been had. The problem was in the hoses being crossed. There is a connection on the rubber hoses where the dual climate control valve meets the metal tubes on the right front wheel well that feed the heater cores. A simple push in and pinch two little tabs, and off they came. I set them right in minutes and everything works as it should. Sure glad I didn't start trying to rewire it. I love an EZ fix!Last edited by Mujiir; Apr 29, 2019, 07:50 AM.
Only one may be having hot flashes.Originally posted by 007Cruiser View PostNever understood why such a tiny space needed dual climate control. If you and your passenger can’t agree on temperature, you may have larger problems to deal with.
In rare cases both could be having this ailment.2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
If you have been on a long road trip during the time of year when having an open window at 65-70 mph is uncomfortable and either the driver or passenger is sitting in the sun & the other is in the shade THEN you will truly understand the significance of dual climate control.
Voice of experience & many long road trips.Mike
