Well... We just got the T-bird a short time ago. This last weekend on our way home we got the sad portends that have been described herein many times relating to coil failure. I have been through the TBN topics and read enough to think that I could attempt this myself. I have gotten the covers off and exposed the coils, and I must say it was much easier that I had feared. I ordered a full set of Spectra Premium C619M8 Ignition Coils (Pack of 8), and a full set of 8 Bosch 9603 Double Iridium Spark Plugs. It appears that only two cops have been replaced so far as the others look to be a lot older, possibly the original ones. Here's the info (hype) on the coil set I bought. "Unit is designed to Original Equipment (OE) fit, form and function requirements accomplished by leveraging Spectra Premium's OE engine management systems design expertise.
All and all, I would say that this is a pretty basic bit of work and could be accomplished by most people that can turn a wrench. Go for it!
- 100% copper base in both primary and secondary windings
- Windings insulated by high voltage enamel coating
- Unit is tested for durability through long-cycle thermal shock test (-50 to 300 Degree F), ensuring reliability against extreme vibrations
- Each new coil is road tested to ensure real world performance and to verify that each design meets Spectra Premium's high standards for quality.
