Originally posted by 4LOWBIRDS+8
View Post
Deja Vu
Good news!! My dealer says this is a big issue because they have customers that should have had their long ago ordered Explorers by now and are not happy. At least the fix will (hopefully) be made before the vehicles get into customer hands. Not a good start for a new, important, vehicle for Ford.sigpic
Skip
Right, yours never left the factory until repairs were completed....Originally posted by Skip View Post
My '02 was built on August 7, 2001 but did not arrive at my dealer until September 28th. It was prepped and delivered the same day. To the best of my knowledge it never left the factory until the repair was made. I, too, was advised it was a cooling system/overheating issue.Quickdraw
Raccoon Lodge Administrator
Thanks for the correction, Lon. :)Originally posted by yelobird2002 View PostIt was the Hydraulic Fan Motor Dot. The bores for the main shaft were mis-machined by a few thousandths putting a bind on the shaft. At an idle the bind was great enough to stop the shaft shaft from being rotated by hydraulic pressure created by the Hydraulic Pump thus allowing the engine to overheat at an idle. Above an idle there was enough hydraulic pressure to overcome the bind put on the shaft allowing it to rotate. So overheat was an issue only at an idle.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
Here are a couple pictures of pictures of cars going back to Factory for the Hydraulic Fan Motor issue from Amarillo, TX Rail head. My Inspiration Yellow is the one on the lower row at the tail end so it could be the first one unloaded. Bill Greens (15 Again) is one of the 3 red ones at the front of the load.Attached Files02 Bird yelo/yelo full accent
20 Ford Escape SE
Looks like the red one on the bottom has a white top, so that would be 15AGAIN. I just didn't know that 15AGAIN went back to the factory.Birds of the 4815AGAIN has been in 48 States and 9 Canadian Provinces. Travelled many miles with great friends-- "Priceless"
