Home alot now with my projects
  • #31
    Lots and lots of landscaping and THEN gone birdie by building Bird House.jpgBird House2.jpg bird houses for Claudia and family!
    Honor the sacrifices our predecessors paid for our country.
    • #32
      Originally posted by Fredrik73 View Post
      Same same but different hihihi
      Fredrick,
      OK I just remembered. I do not have a schematic of the FEM. If you have the electrical service book like mine, then this is how you reverse engineer it:
      Get an Ohm Meter with sharp pin test leads. You need to break through the clear coating applied to all components.
      The MOSFETs transistors have Gate and Source marked as G and S. The Drain pin is in the middle and is not marked. That is the one you want to connect to most of the time.
      The power window MOSFETs are N Channel since they apply a ground to operate (just like tail lights and headlights), go ahead and measure from pin 1 and/later pin 2 of FEM connector C201G.
      From pin 1 and later pin 2 measure a short or very low resistance to all 11 MOSFETS Drain (the unmarked middle pin).
      Locate which Q # (like Q21 etc) is associated with pins 1 and pin 2 of FEM connector C201G. This connector has 4 big pins to handle FEM power and Driver's Power window.
      After you have found which Q numbers correspond to C201G pins 1 and 2, let me and all of us know.
      When I have time I will try to identify all the other MOSFETS and recommend replacement part numbers and sources. The lights should be easy. All the N channel transistors should be the same. So far, I have only found two P channel circuits, dash lights and power steering solenoid.
      Time to stop information overload. To be continued.
      Hermann
      • #33
        I think you should have a whole new thread under “How to fix it” so that future people will be able to find this important information.
        • #34
          Can they be custom built and ordered?
          • #35
            Gene,
            When complete, I will cut and paste and put it all together in the how to fix it thread.
            • #36
              Gene,
              Excellent
              • #37
                Ok I will look them up and tell you what each one does.
                Hermann
                Q35 is power steering and is PMOS MOSFET positive.
                I got the holders off today so i can see the text on the MOFETs
                IC18 : 62971 6611 MAL 70500FB CS0207C
                Q25: 76419P Y2 08 F ABN
                Q34: 76419P Y2 08 F ABN
                Q21: 5125FE I (Diodsign) R 216G OD41
                Q32: 5125FE I (Diodsign) R 216G OD31
                Q29: 5125FE I (Diodsign) R 216G OD41
                Q26: 5125FE I (Diodsign) R 216G OD31
                Q31: 5125FE I (Diodsign) R 216G OD41
                Q35: RF3505 I (Diodsign) R 213G 08A5
                Q28: 5124GE I (Diodsign) R 140E 2300
                Q36: IRF 5305 I (Diodsign) R 213G 08 A5
                i think it is a diod sign between the I and R
                see picture
                • #38
                  om Hoping to find all new and replace them
                  • #39
                    Gene,
                    If this is not going well i need help to find a new FEM
                    • #40
                      Nice birdhouse
                      a hole village for birds
                      ​​​​​​/Fredrik
                      • #41
                        Fredrick,
                        Hermann
                        Oh this makes me want to get out in the garage right now but its night here so i have to so it tomorrow, it sounds like thats the one making problem.
                        i Will tell you all when i have tested it
                        thank you Hermann
                        • #42
                          Q36: IRF 5305 I (Diodsign) R 213G 08 A5 (may be a regulator)
                          see picture
                          OK Fredrick.
                          1 How did you get the black steel holders off? And how do you propose to get them back on.
                          I know Swedes are very smart and I would like to see if your method is better than (German) mine.
                          2 The numbers are meaningless but useful since I do not have access to the FEM manufacturers catalog.
                          Once I determine that one (MOSFET) transistor is N or P type then I can determine that the other ones with the same part number are also an N or P transistors.
                          I can then recommend replacement MOSFET transistors.
                          3 Fredrick, do you have the time to find where each of the MOSFETs Drain (middle unmarked pin) pins go to what pin on which connector?
                          It is doable but time consuming and 3 or 4 hands may be better than 2 when holding the Ohm Meter probes. Unless you can find way to
                          clip to each male connector pin you are testing.
                          Hermann
                          P.S. The diode design means International Rectifier Corporation, Manufacturer of the part.
                          Also, I could determine which pins you need to connect to by looking at the FEM drawing.
                          Stand By
                          • #43
                            Plug pin number to Q Power transistor numbers I have started on, will be here. I will edit this post as I add FEM info.
                            Connector:
                            C201a
                            pin 9 goes to Q35 Power Steering.
                            pin 4 goes to Q__Turn Stop Hazard Lamps.
                            pin 5 goes to Q__Turn Stop Hazard Lamps.
                            pin 6 goes to Q__External Lamps
                            pin10 goes to Q__Auto Lamps__
                            pin17 goes to Q__Auto Lamps
                            pin 7 goes to Q__Auto Lamps
                            pin 8 goes to Q__Auto Lamps
                            C201C
                            pin 2 goes to Q__Turn Stop Hazard Lamps.
                            C201e
                            pin 11 goes to Q36 ??? Instrument Cluster
                            C201g
                            pin 2 goes to Q__ Power Windows
                            pin 1 goes to Q__ Power Windows
                            C201b
                            pin21 goes to Q__ P93 Battery Junction Box Relays K321 K322 K323 K324
                            pin14 goes to Q__ Windshield Washer Pump
                            To be continued
                            • #44
                              see picture
                              You will also need 11 new .insulating sill pads for the transistors.
                              IC18 may be a regulator and may be the entire problem. You need to apply 12 volts to the power plug and measure the pins and see if 12v goes in and what comes out. Maybe +5 volts comes out.
                              I don't recomend replacing all transistors.
                              • #45
                                Fredrick,
                                Hermann
                                Hermann
                                i m now sitting and testimg
                                i cant find that any MOFET are connected to pin 1 or 2 from C201G i get no contact
                                i will now try C201G
