Originally posted by Frank Dreano
View Post
2005 T-Bird - Use of Manual Shift (AKA Slap Shift)
I do not have Borlas on the Grey Ghost but do have K & N CAI which has a nice rumble under load. Three or Four times a year I get the urge to do the select shift through the gears. Obviously start in first and floor it. Shift through each gear at slightly more than 5000rpm. Car sounds good and performs very well for a V8 which is smaller than the 260 ci I had in a '63 Falcon (first ) convertible.Originally posted by BillyL View PostIt is your car so drive it like you want to. Just keep us posted on the results. I see our cars as boulevard cruisers, not street legal race cars. I would be concerned over revving with aggressive manual shifting will have other negative outcomes besides transmission problems.
(Good Lord, could that have really been 55 years ago?)
Ha! I had a 63 Comet convertible with that same motor - the first V8 I ever rebuilt...Originally posted by wcoates View Post
But, you can't really compare modern fuel-injected cars with i'smart' ignition timing, "intelligent" shifting and other computer controlled do-dads against low-tech/no-tech 60s motors.
I would think there are exceptions including my 66 mustang with 289 K code 271 HP would smoke the Retro even at an altitude like Lake Tahoe. No computer necessary, just raw HP.Originally posted by Frank Dreano View PostHa! I had a 63 Comet convertible with that same motor - the first V8 I ever rebuilt...
Going off-topic, but my wife's 6-cylinder 2016 Durango would shut down my original base motor 63 Corvette; its just the way it is...Originally posted by carntz View Post
And - I want your Mustang if its a true HiPo
Well my re-builder (reputed to be far better than factory re-build) came back early so I got an answer to my main concern
"Use it if you choose it" .. "Ford put it there to use" .. "used properly, it's likely better on tranny than Drive .. and more fun to some"
Thanks for all the input - My decision is based on assessing "all" adviceRalph & Jenn from BC Canada
Our Gallery is new, but growing fast
is your '63 a 250hp? Mine was 375hp if my memory serves me...there also was a 300hp..correct?Originally posted by Frank Dreano View Post
I still have the split window car and its the 250hp "base" 327ci...original numbers matching with one overhaul in 2004...
All other motors were cost upgrades; 300hp 340hp and then fuel injected; the SHP motors (last two in list) being solid lifters.
Sounds like the young man who started this thread has considered all that was posted/said and come to his own conclusions...which is good.
[QUOTE=Frank Dreano;n1080896]I still have the split window car and its the 250hp "base" 327ci...original numbers matching with one overhaul in 2004...
Sounds like the young man who started this thread has considered all that was posted/said and come to his own conclusions...which is good.[/QU YOU'RE CORRECT Frank, my '63 was 340hp
