HI , I want to delete the automatic tilt on the steering wheel and leave it in a fixed position ?
telescopic delete
I think you can remove fuse #19 (15amp) in the fuse box located by the passenger's right foot to disable the telescoping and tilting. Make sure the wheel is where you want it when you pull the fuse.
And your reason is ..... ?Originally posted by VIno Bird View Postthanks for the tip , first mod when Vino gets here :)21 years, 174K miles, 48 States X 2 & DC, 9 Canadian provinces, 8 European countries, 3 Caribbean Islands, 3 Hawaiian Islands, 100+ National Park locations, 150+ T-bird events, 190+ retrobird diecasts/models, 13 TOTM pics & some very special friends...THANKS TBN !
That absolutely works....I had to do that trick to disable the "tilt and extend" when I pulled the instrument cluster...Originally posted by 2K2BIRD View PostI think you can remove fuse #19 (15amp) in the fuse box located by the passenger's right foot to disable the telescoping and tilting. Make sure the wheel is where you want it when you pull the fuse.
After fourteen 2002-2005 Thunderbirds and over 280,000 miles I say if it isn't broken, leave it alone.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
If you really want a mod, do this.Originally posted by VIno Bird View Postthanks for the tip , first mod when Vino gets here :)
merlot.jpg02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
Sawmiller first and farmer second.Originally posted by 007Cruiser View Post
You must have been a farmer.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
When I pulled my instrument cluster I had the steering ass'y covers off anyway so I lubed up the screws and sliders for the "tilt/extend" function...it made a noticeable difference in operation - they were pretty dry.
You might do likewise if you're worried about it and leave the fuse alone.
