I am about to buy this bird from a friend of mine
So far it has a battery drain problem and a water leaking problem with a hose ( no major problem with the hose)
I drove the car home to check it out and it has not moved since. It had sat for three years so I replaced the 7 year old battery and it restarted fine.
The next morning the battery was drained and the car would not start. I put the charger on it and it cranked and started . The next day it would not start again.
I removed the positive cable and charged the battery when I connected the terminal I noticed a large spark at the terminal so I used my amp meter to measure the drain on the battery was 16 amps and all the external lights were on. I checked the light switch and it was off. I pulled the SSP 1-4 relays to kill the lights and the fog/running lights were still on so pulling the fuse to that circuit killed that light also.
The car still would not give any indication when the key was inserted . After replacing all the parts removed it still had a drain. I left the positive terminal disconnected for about 1 hr. I connected the terminal and the car started. Any ideas as to what would cause this problem?
