Finally fixed the only thing that was not working in the T-bird, it has been a while maybe two years it would work intermittent not working most of the time and when needed the most it would not work, I would have to press the button 15 times and sometimes it would work anyway the other day I got my Power probe, wiring diagram and repair manual.
First thing I did was to disconnect the wiper motor connector, that connector seemed like it was welded on I attribute the heat in the engine compartment for that, had to pull hard to brake it loose all of a sudden it started raining so I decided to reconnect it and try again at a later time, the next day I got in the car and decided to give it a try, to my surprise it worked all the time so I decided to disconnect the connector again and used Electronic Contact Cleaner spray and a little dielectric grease.
It is been three weeks since then using the windshield washer almost every day, so far so good.
