I was taught by my father that you warm up your car in cold weather. When I was a little girl my father use to go out in the cold and warm up his Road Runner. I followed this ritual for as long as I could remember. However, I have heard it a few times that it is bad to leave your car running idle for a long period of time. My Raven sleeps in the garage with her cover and away from the cold, but I do warm her up in the morning. Do these new age computer ran cars need to be warmed up? Or am I just following a old learned tradition that my father practiced?
To warm or not to warm is the question!
Re: To warm or not to warm is the question!
I've seen several queries re. warming - all said "not necessary for modern cars" - I assume this excludes cars sitting under 3" of Canadian ice -anyway, I think waiting for the tach to roll back is sufficient, especially for a house kept bird.sigpicRIDGE TOP PERCH FOR A THUNDERBIRD
My car is garage kept, the above is what I do, starts at ~1,600, rolls back to ~1,000. If I put it into gear before it rolls back, there's a slight clunk and lurch.Originally posted by austx View Post[I]...I think waiting for the tach to roll back is sufficient, especially for a house kept bird...PK- 2002 Premium Blue/Full Accent/Whisper White Top
VIN#16336
Built April 22, 2002
Purchased July 24, 2002
That clunk would be the transmission. Not healthy for it.Originally posted by Borla Babe View PostI've heard that clunk
, what exactly is it?
Ditto on the tach rollback, no clunk.Lonestar
I think the main reson to let your T-Bird or any car warm up depends on what the weather conditions are. A warm engine will respond better and give you the heat you need for defrosting and defoging conditions and it's also not a good idea to run an engine at higher RPMs untill the oil has warmed up to the right viscosity. Also during the Winter months it's not a bad idea to run your A/C every once in a while for a little bit. I helps keep the seals and O rings from drying out. Leroy
...here in Phoenix, about 15 seconds on a cold car is maximum!Originally posted by 00mustng View Post....tach rollback...no matter what the weather....right now, for mine @-25C...about 5 minutes....just to get liquids warmed...and the heater going.....
Is this necessary? Isn't the compressor always on if you keep the system on "auto" to the keep the windows from fogging up in the winter?Originally posted by Leroy View PostAlso during the Winter months it's not a bad idea to run your A/C every once in a while for a little bit. I helps keep the seals and O rings from drying out. Leroysigpic
2010 Jaguar XK coupe
1985 Honda Nighhawk "S"
2013 Lexus RX350 - wife's
2013 Mercedes E-350 coupe
If you do use this practice of warming the engine remember to still drive slow for the first couple of miles.With a warm engine the rest of the vehicle is still cold ,shocks ,springs , front end parts etc. My Brother -in - law has a repair shop in N.Y. he loves the freezing weather he says"this is when people break-up there cars from the cold". Some will warm up the engine and head down that country road with bumps and ruts at 65sigpic
If you are set to Defrost it should kick on but only down to a certain outside temperature, at least that is what was said for some other cars I have owned. (My owner's manual is in the Bird in storage)Originally posted by V8 Cat View PostIs this necessary? Isn't the compressor always on if you keep the system on "auto" to the keep the windows from fogging up in the winter?
Martin
Martin
These days, idling is a no-no. that is why many manufacturers of Hybrids have automatic engine shutoff when stopped at a light. It is illegal in some states, california especially, to sit at idle while standing still for a length of time.
With the TBird, I also wait for the tach to drop to 1000, but I do it only because of the transmission clunk. That is hard on the car. With my other cars, I delay putting them in gear for only about 15 seconds, just to get the thick oil moving. Modern cars are very different from pre-80's cars and don't require the same 'rules' that we were taught.Last edited by DavidA; Dec 18, 2008, 08:03 AM.Unbelivable TBN trips including ALL of the lower 48 States plus 9
