I have an 02 TBird. On top of the engine is a plastic cover that says Thunderbird and V8. It attaches in 3 places. In the upper right corner there is a hole for a plastic anchor, just like the one below it, but there is only a hole with nothing underneath to attach it to. The Ford dealership is also stumped. The plastic cover needs to be attached there as it is very loose in that corner. Any suggestions?
Stumped in Seattle
Re: Stumped in Seattle
If George were home right now, I'd post a picture with the cover off so you could see what might be missing. I'm too chicken to take the cover off myself for fear of breaking one of those push pins, but at least I did notice that George or someone put the wrong pin in one of those holes - will have to get on George about that.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
George came home early. Have loaded a picture. It's the bracket that you see in the center of the picture. Appears to be it's only purpose is to hold that cover in place.
(you can click on the picture to view it larger)Attached FilesLast edited by 5bird7; Apr 23, 2009, 12:25 PM.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
I'll get another picture later tonight. guess I should have taken a few more when the cover was off.
I did take a picture of the cover's underside and labeled it. You probably already know what it looks like but other's don't.
Got the cover off and added details to the engine photo
Bracket D, as I've labeled, I think is the one you say is missing?
It appears to hold more than just the cover but also has a hose clamp attached to it and appears to channel that same hose. I'm going to look it up in the manual so you can see how large the clamp is.Attached FilesLast edited by 5bird7; Apr 23, 2009, 06:19 PM.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
Here's a close up of the backside of the bracket. You can see where the hose clamp is anchored on the backside.
2nd picture is what the bracket looks like as found in the manual.
page 303-04-7 of the 02Workshop ManualLast edited by 5bird7; Apr 23, 2009, 06:54 PM.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
By the way, that bracket picture from the book was in the fuel system section. They called it the "Engine Cover Appearance Bracket"Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
umm - that's what is under the cover - it does look like it needs a good cleaning there (not George's jobOriginally posted by Borla Babe View PostDot
, is that dust I see on your engine?
