Re: Squealling Sound from From of Engine When Its Cold
My car had similar symptoms, mostly chirping when first started when cold.
Looking at the belt I found it had many small cracks and was glazed.
I bought a Gates replacement for $30. It is an absolute b*tch to replace it. Anyone who thinks you can just pop one of these on has never done it. You will find that after you remove the air intake and the engine cover you can barely get your hands past the fan shroud, and you cant' reach down to some of the drive pulleys and have to do it by remote control.
You will also find the you can't get the old belt out or the new belt in because it is trapped in behind the tensioner arm. You can cut the old belt and pull that out, but the new belt won't squeeze back in, so you must (at least) loosen the bolt that secures the tensioner assembly to the engine front cover so you can pull the tensioner away for clearance. That happens to be behind some coolant hoses, how nice.
You had better draw yourself a belt routing diagram before you start, you will never figure it out afterwards if you don't.
The good news is, after sacrificing my hands and arms, the new belt cured the problem.
Drive belts are considered a wear item by most extended warranties (like brake pads) so you may want to check to see if its covered.
