2003 Axle Ratio
  • 2003 Axle Ratio
    Had a hard time finding out what the axle ratio was for my '03 Bird. It's 3.58. I don't know if it changed through out the generation, but probably not. Anyway, thought I'd share.
    Re: 2003 Axle Ratio
    These days? People don't talk about the axl ratio so much.
    Transmissions really skew the need to consider the trade offs in the Axel ratios anyway. I think that's why you don't hear as much talk about the subject as you used to.
    Before over-drive transmissions..........4 speed manuals and 3 speed automatics?
    A final drive ratio of 1:1 meant you had to weigh the idea of a 1/4 mile SCREAMER with horrible cruising characteristics and bad gas mileage vs a car that would have a less than easy time giving you it's best acceleration out of "the hole" yet gave good MPG and didn't require you to play the radio at full volume just to drown out the engine noise at 60 mph on the high-way.
    2 years ago I sold a 1996 Camaro Z28SS with a 6 speed manual I bought in '96. It came with 3.42 gears.............in years past this would have been a middle point between cruiser and drag strip ready.
    That 6 speed had a predicable 4th gear ration of 1:1. It also had a 5th gear ratio of .70:1 and a 6th gear ratio of .50:1
    Ultimately 6th gear was nearly useless.
    2000rpm at 80 mph meant using 6th rarely happened.
    A swap to 4:10 gears would have been a tough choice in the 1970s...........3,500rpm cruising at only 60MPH is nobody but a deaf person's idea of a reasonable trade off.
    The '96 6 speed though?
    4:10s actually produced a car that JUMPED off the line and turned a very reasonable 2,000RPM at 70mph.
      Re: 2003 Axle Ratio
      "with 4:11 gears you can really get lost"
        Re: 2003 Axle Ratio
        Ahh........funny how those ring and pinion tooth counts work. At least I suspect that is the difference.
        For what-ever reason my old Corvette has 4.11s and the Camaro I no longer own had 4.10s.
        I've never actually looked at the gears in either car.........I'm gonna GUESS how-ever that the tooth count is different.
        A ring with 41 teeth and a pinion with 10 would explain a "4.10" ..........not sure what would explain 4.11s.
        A ring with 37 teeth and a pinion with 9 teeth? ......a little higher than 4.11.... closer to 4.12.
        Honestly, it makes my head hurt just thinking about it.
        Besides, lapping and shimming gears is above my mechanical abilities anyway.......so it's not as if I'm ever gonna be in there to count 'em.
        It's enough for me to know that you're absolutely correct.
        Higher ratio gears really are a great performance upgrade for many modern cars with over-drive transmissions.
        I'm surprised you don't seem to see it done as often today as in years past.
        Then again the T-Bird isn't much of a candidate for it.
        The lack of a protraction rear end means all you'd get is a big cloud of tire smoke from one wheel anyway. Not much of anything good in that.
          Re: 2003 Axle Ratio
          Chevy terms.........Positrac
          Ford terms...........Tracloc
          If you have enough horses and the wrong surface it's a cloud of smoke from both wheels and some interesting driving
            Re: 2003 Axle Ratio
            Lowest rear end ratio I've ever driven in a street car was 5.14/1. It was a friend's 1956 Corvette, and those were the days when high gear was 1/1.
            I ran 4.11s in my 57 BelAir. Even that was too high on the highway for a car with 14" tires and 1/1 final gear ratio.
            But, what a difference when compared to the stock 3.36/1 ratio.
            My 65 Corvette came out of the factory with a 3.08 ratio (by accident) instead of the stock 3.36. Ridiculously low rpms at 100 mph, but kind of sluggish off the line, for a Vette.
              Re: 2003 Axle Ratio
              .........spell checkers..........never know what they'll do if you don't re-read after using 'em.
              Truth be told the new T-Bird is a weak performer in terms of Horse-power and most certainly weak on what we're REALLY talking about here...... it's "torque" that gets a car moving from a stand-still.
              The little V8 is great looking engine when you lift the hood but for a car this heavy a few more cubic inches and bunch more power would have been a welcome development.
              ........and then maybe Ford would have given us a Positrac rear end (sorry you can put a Ford in Chevy guy's garage but that in itself will never erase 30 years of calling it a "posi")
              The T-Bird is a cruiser........single trac is probably the right choice for a car that struggles to make power at under 2,500rpm anyway.
                Re: 2003 Axle Ratio
                My other car is a Corvette automatic with the performance 3.15 axle. It will knock you back in the seat if you deck it at 80. In the past, I had some muscle cars with 3.90 and 3.93's. Actually, a lot of people swapped there gears because it was an inexpensive way to give the car a kick in the "harse." Now it's expensive along with everything else.
                  Re: 2003 Axle Ratio
                  Pappy said, "Son, you're gonna drive me to drinkin' if you don't stop drivin' that hot rod Lincoln." Oh man, I must be old!!
                    Re: 2003 Axle Ratio
                    The truly "cool" thing about old Corvettes is you can have it both ways.
                    I suppose that I'd have to agree with you on the costs involved with the latest Corvettes.........but.....
                    For the older cars? Those built between 64 and 82 anyway........
                    Owning 2 or more sets of gears in their carriers is the way to go. With different gear ratios, you can swap 'em in and out in about an hour once you've done it a couple of times.
                    I've got a heavily modified 1979 that used to make frequent trips to the drag strip. 3.08s for everyday and 4.11s for the 1/4 mile were swapped in and out a couple of times a year.
                    Today the car is set up for road use. My wife actually drives the car. So it's been a long time since I last swapped the gears..........today transverse fiberglass springs and koni shocks front and back along with stabilizer bars so fat the car drives like a dream vs the harsh ride an available performance suspension would have given you 20 years ago.
                    Ultimately it has a place in my garage still because it's just fun both to drive and work on.
                    It's also a harsh reminder of the only real disappointment I have with the T-Birds.
                    Low production numbers in this 4 year run of Retro-Birds means you don't see one at every traffic light all summer long and I like that..........but it also means the available aftermarket is horribly thin and likely to get worse as time goes by.
                    The weaknesses in the car will mostly go undressed and that's a shame for someone like me who buys a car and hopes to hold it for a long time.
                      Re: 2003 Axle Ratio
                      I think gear heads like many of us have been so lucky to have been around in the early performance days, 1950 to 1974. Who can forget the Muscle cars from 62 to 73?
                      They were easy to buy and easy to work on to get even more HP.
                      Then the Government got involved in emissions, and safety (see Ralph Nader) and as this government does, screwed the pooch. High octane gas was not made for general use.
                      It took ten years and lots of engineers to get the cars to start to perform again. But the cost went to the roof.
                      Now we have muscle cars everywhere. Most cars of today could keep up or better many from the late 60’s. And we don’t need a mechanic to keep it in tune, just a computer wiz.
                      But again the government is screwing the pooch. They don’t like the fuel we use and want us to be green. Or use wind to sail down the hi-ways. In the next few years, if people still have a job and can afford a car. It will have a total of 190 hp some times and at a car price of about $25 to 30 K.
                      Or pay $106,000 and get a Lexus LS600h with 438 HP, but wait a minute this only gets 22 MPG hi-way 2 mile less a gallon than their regular LS600 L.
                      This must be a Hybrid car for Al Gore and his cronies. :flames:
                      So the Government is taking us to the green zone and we will pay through the ass for everything and get bad performance. Well in ten years they will engineer better cars so we will have fun cars too drive and the government will say the planet is too cold so lets burn petroleum and coal, because we have so much of it and the government can TAX it.
                        Re: 2003 Axle Ratio
                        Here ya go:
                        Have you heard this story of the Hot Rod Race
                        When Fords and Lincolns was settin' the pace
                        That story is true, I'm here to say
                        I was drivin' that Model A
                        It's got a Lincoln motor and it's really souped up
                        That Model A body makes it look like a pup
                        It's got eight cylinders, uses them all
                        It's got overdrive, just won't stall
                        With a 4-barrel carb and a dual exhaust
                        With 4.11 gears you can really get lost
                        It's got safety tubes, but I ain't scared
                        The brakes are good, tires fair
                        Pulled out of San Pedro late one night
                        The moon and the stars was shinin' bright
                        We was drivin' up Grapevine Hill
                        Passing cars like they was standing still
                        All of a sudden in a wink of an eye
                        A Cadillac sedan passed us by
                        I said, "Boys, that's a mark for me"
                        By then the tail light was all you could see
                        Now the fellas was ribbin' me for bein' behind
                        So I thought I'd make the Lincoln unwind
                        Took my foot off the gas and man alive
                        I shoved it on down into overdrive
                        Wound it up to a hundred-and-ten
                        My speedometer said that I hit top end
                        My foot was glued like lead to the floor
                        That's all there is and there ain't no more
                        Now the boys all thought I'd lost my sense
                        And telephone poles looked like a picket fence
                        They said, "Slow down! I see spots!
                        The lines on the road just look like dots"
                        Took a corner, sideswiped a truck
                        Crossed my fingers just for luck
                        My fenders was clickin' the guardrail posts
                        The guy beside me was white as a ghost
                        Smoke was comin' from out of the back
                        When I started to gain on that Cadillac
                        Knew I could catch him, I thought I could pass
                        Don't you know by then we'd be low on gas
                        We had flames comin' from out of the side
                        Feel the tension, man, what a ride!
                        I said, "Look out, boys, I've got a license to fly"
                        And that Caddy pulled over and let us by
                        Now all of a sudden she started to knockin'
                        And down in the dips she started to rockin'
                        I looked in my mirror; a red light was blinkin'
                        The cops was after my Hot Rod Lincoln
                        They arrested me and they put me in jail
                        And called my pappy to throw my bail
                        And he said, "Son, you're gonna' drive me to drinkin'
                        If you don't stop drivin' that Hot Rod Lincoln!"
