Re: A little help please!
Thank you very much Guys!
All is clear and thank you very much Mike for the detail. I have spoken to a Ford tech who tells me the only sure way to check the switch is to replace it as even one that looks good might not work, hence the PCM giving no fault codes also.
Damn difficult thing to fault find, especially as you have to be moving at >35MPH to make it work, the other problem being the light on the dash not coming on with ignition test.
Holding the trip reset while switching on the ignition to enter the test mode proved the bulb during the test routine.
I'll post and let you all know the outcome once a new switch is fitted.
Many many Thanks again for all you're input...
David
David
