Contol on Steering wheel not working
  • Contol on Steering wheel not working
    This is not a new problem and one that I probably will not worry with, however, the Volume and other switches on my steering wheel(not the cruise control) do not work. They never worked when I bought the car last year. I have never wanted to worry with it until now. Anyone know about this?
    Re: Contol on Steering wheel not working
    clock spring most likely needs to be replaced. It's in your steering column.
    Do a search on "clock spring" and you should find more info about it.
      I had the same issue when I purchased my '02 in August. It also affected an airbag sensor in the steering wheel. Is your airbag light illuminated on the dash? I had the clock spring replaced since the original owner agreed to cover the expense and deduct it from the selling price. We took it to a local Ford dealer and, if I can remember correctly, it was around $300.
        Clockspring replacement
        Here are some details about the clock spring:
        http://www.thunderbirdnest.com/forum...40&postcount=9
        http://www.thunderbirdnest.com/forum...63&postcount=6
        ~Jimmy
          Before you check the clockspring...Do you have an aftermarket radio?
          "Probably good enough, isn't"
          ~Grandad
            . . . and a lazy/penurious installer? That was my first thought, as well. My radio is aftermarket and my buttons work.
