To all Falken owners
  • #31
    Re: To all Falken owners
    Originally posted by Ol'Dave View Post
    When I did the pass thru sale/purchase on the IY, the Dealer had to put new shoes on her. She had the original OEM's, but sidewalls were toast. He put on Falken's. I have no complaints, ceptin I wanted wide white walls. Now I have to wait. On MMM, I have the Vogue's. Love the fit (fills the wheel wells better) and the look (from 20 feet or more). Yes the diamond design in the whitewall itself is a bugger, and attracts everything. Even with the "Clean-wheel" disks. The Gold stripe accents the Sand interior very nicely. BUT, when, and if, they ever wear out, they will be replaced with Michelin's from Diamondback with a nice smooth wider white wall. I run 35 psi in them. Absolutely.....no issues.
    Didn't see you or your IG at Toms Thunder Zoo Cruise.
    Is it left up to only me to represent IG at the cruises?
    • #32
      decided on cooper cs4 touring....put these on the caddy...low road noise,handle and ride great...not real impressed with the mich...28kmi and their toast....going with org size 235/50/17
      • #33
        I THINK HE HAS AN IY, NOT AN IG.
        • #34
          His picture of the car looked like an IG to me even though he did write IY.
          OK Dave which color is it?
          • #35
            Originally posted by ChromeDome View Post
            Jerry asked for opinions from Falken owners.. I seem to be the only owner to answer.. Maybe I have to only set on TBN. In defense of Diamondback and Falken tires, I don't think Diamondback would stake their reputation on an inferior product. Also, at $279 per tire, they are hardly cheap. They are also "W" speed rated. The installer at the Ford dealership was really impressed at how easy they were to force balance. He said as a set they were the easiest to balance and the truest round that he had ever installed. I value his opinion since he has many years experience.
            I don't believe that the opinion of non-owners will be of much value to Jerry in his quest to purchase new tires.
            I have my 235/55ZR17912W Falkens from Diamondback for two weeks. So far so good. Running at 35lbs, feels great for what that means. Falken Tires are used and have a car in the American Lemans series. I drive mine during Wisconsin's Spring, summer and fall seasions at or about 5000 miles. IMHO it's the look that I want to go with what, I feel is really the retro look that Ford should have done.(Thanks Treken for the grill trim)
            sigpic2002 Black Premium Black Accent
            1996 LX Black with gray interior, 4.6 V-8
            • #36
              Add Picts
              • #37
                Dick, I was told to run 41 psi by DiamondBack in my Falken 912s, which should be delivered late this week.
                • #38
                  Jerry,
                  Wow! Let us know how that rides. At 41 psi, I would think that would really create some rattles and excessive cowl shake. 41 ps1 cold is going to be even a couple of pounds or more higher after they get on the highway.
                  2010 Jaguar XK coupe
                  1985 Honda Nighhawk "S"
                  2013 Lexus RX350 - wife's
                  2013 Mercedes E-350 coupe
                  • #39
                    41 was recommended due to the Falken sidewall structure.
                    Other brands of tires, lower pressure.
                    We'll see.
                    I did read that Falken owners felt their tires were "squishy", and higher psi did make a difference.
                    • #40
                      Originally posted by rerdmann17 View Post
                      Add Picts
                      I started at 35lbs because that's what has always felt best and performed well. I'll try different settings and see what works best .
                      • #41
                        Trying to post picts. Hope this works.
                        • #42
                          Tires installed today.
                          First impression (short trip home), 41 psi is not too much. No new rattles, even with the hardtop on.
                          Second impression, glad I didn't get the MSG top. IMHO, black car, white walls, MSG top, Saddle interior=too much.
                          Third impression: should have gone with my gut, but I'll hold off any explanation until I get more accustomed to the new look.
                          As soon as we get some decent weather and I can wash the car, I'll post a picture.
                          Car's pretty dirty since the Galaxie motors (old block and new block) and parts took over her garage.
                          • #43
                            Here's the new tires.
                            Since the retro is a cross between old and new, I figure the tires are as well. Not full whites, like the first TBirds, but not thin whites either.
                            Also, ww go well with the TBird's white circle in the cap.
                            No problem yet with 41 lbs.
                            Hind sight, I probably should have gone for a little smaller black edging. 1/2" black edge, IMHO, pushes the 1 1/2"ww out too far. 1/4" edge probably would have been perfect.
                            My fault for not asking when I ordered.
                            • #44
                              Very nice, Jerry. I like them better than the Vogue's on black.
                              • #45
                                Originally posted by V8 Cat View Post
                                Two good reasons for not running 40 psi, and I have another one. If you have a blow-out because of tire failure, you would never be able to pursue any litigation against a tire company running that kind of pressure.
                                My Falkens have a max PSI of 52 PSI marked on the tire.
