cd error
  • cd error
    cd player is stuck. cd error message appears. it will not eject or play. any suggestions.
    Re: cd error
    That's normal for these radios. Do a search on the site and you'll find lots of info on this subject. I just had mine rebuilt after 9 years of use.
      Re: cd error
      Hi Murray,
      Here's a list of prior threads and posts about stuck CD players.
      http://www.thunderbirdnest.com/forums/search.php?searchid=424348
      If it's just one CD that's stuck in the slot, you can gently jiggle it loose with a credit card and remove it. I used to refer to the manual and perform an "All Eject" and just start over loading...just depends on what works for your player.
      Good Luck
      Redbirdsal
      IRISH THRU & THRU!
        Re: cd error
        ....you might find that the cd will eject by itself after the unit cools down, as has happened to me, Sally....
          Re: cd error
          The last two times I used mine, it would not eject. Sometimes, you can get them out using a slim tool, like another CD. Sometimes, not. But, both times, after two days, it came out by itself. I assume the condition will not improve, so will have to be satisfied with just the radio. You may have noticed the radio is not great either.
          I would guess if you have it replaced or repaired, the problem will reappear at some point. Not a great unit.
