Road Force Wheel Balance
Excellent. Thank you professor! Guys after using the link, use the search option for specifics. Three articles should all be read.
Will anxiously await Roger's/Bonnie's response regarding results.Bill Coates-Canfield, Ohio
I try to get my numbers (road force) down to under 8 or so that the motorweek link mentioned on my Lincoln Mark Viii and it helps. I've always had low road force numbers on my Tbird with my Ohtsu's. Go figure! When one does mount a tire to a rim there's a mark that aligns with the valve stem and that insures that the runout of the rim and tire will "match" and help cancel out each other.
WOW! You really need to get that handled..... After all, changing drivers while still rollin' would be difficult enough with balanced tires yet alone having a rough ride.Originally posted by Vintage Merlot View PostYes. Usually on road trips. We change drivers every 100 miles and keep rollin on.
Wow I think someone should clear this up for you.Originally posted by RustyFrye View Post
WOW! You really need to get that handled..... After all, changing drivers while still rollin' would be difficult enough with balanced tires yet alone having a rough ride.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
