This has been going on a while now. When I am driving slow and go over a dip or bump in the road I hear rattle sounds like under the front area of my car or under upper hood area. I put new struts on it right after I purchased the car. All was quiet. Now with 26 thousand miles on these Monroe struts/shocks the noise gets a little worse. Has anyone had this problem if that is what it is?
Rattle under front end when I drive over road bumps slowly
Like you, I replaced most every front end part just after I purchased my 02. It had about 115K miles and I thought it would be good preventative maintenance. All parts were changed except...the front sway bar bushings, I didn’t do those...they are a bugger to do. Two new bushings are in my parts box. Someday, maybe, I’ll get the ambition to change them out. I wonder if that could be the source of your rattle?Pensacola, FL
02 Whisper White
I agree with those saying to check the sway bar bushings. My son's '06 Mustang had a thump or rattle sound (hard to explain) at only slow speed and we replaced the sway bar bushings and that fixed it. It was an easy inexpensive repair so I hope it could be that simple for you.
I checked mine there is rubber loose around them, probably original no grease ones. I looked you can get the greased fitting ones for (both) for around 25 bucks not bad. I will get to them as soon as I can.Originally posted by StevenM View PostLike you, I replaced most every front end part just after I purchased my 02. It had about 115K miles and I thought it would be good preventative maintenance. All parts were changed except...the front sway bar bushings, I didn’t do those...they are a bugger to do. Two new bushings are in my parts box. Someday, maybe, I’ll get the ambition to change them out. I wonder if that could be the source of your rattle?
Thank you guys
Just got it back and wow the car seems to steer better and no rattles. Nice and quiet now.
