Normal Engine Temperture
  • Normal Engine Temperture
    What is the normal temperture position on the guage. My is about in the middle.
    Gary
    Re: Normal Engine Temperture
    about the middle
      Your temp gauge is basically an analogue idiot light…. The pointer will stay in the middle as long as the engine temp is running within specs. The pointer will not creep up or down. If you engine were to start running hot you will not know it until the it reaches the high level limit and at that point the pointer will jump into the hot area. This is typical of all gauges used in FoMoCo vehicles for some time. Normal operating temp is 200 to 210 degrees. Hot is approx 240.
        Interesting info, thanks. Seems like mine is running fine.
        Gary
          in the blank LED display space on the right (mirroring ODO) , it would be kewl to get a computer mod to display specs like voltage and temperature!
          archie Select Shifting all the way!!
          PCR #363
          GOLD 2007 VW EOS
          GOLD 98 Saturn<RIP>
