soft top boot
  • soft top boot
    I have not been putting my soft top boot on because it is so hard to snap it down. Saw some replacement boots while in Dearborn and was about to order one when I figured if the original snaps don't work well the new ones won't either. Had previously used a hammer to secure them but today I just pushed firmly and it snapped in place. Possibly if I put some WD40 on the snaps they will be easier. Anyone else have this problem and suggestions?
    Re: soft top boot
    Tom, Try a small amount of white lithium grease on each one.
      Re: soft top boot
      Vaseline works good too
      Brian Metzger email metzger_b@sbcglobal.net
      '03 James Bond 007 edition, CORAL
      2010 Taurus SHO- Cinnamon
      1964 Falcon Futura H/T
      2015 Taurus SHO - Silver
        Re: soft top boot
        I'd use either suggestion above, over using a spray.
          Re: soft top boot
          soap works also. be carefully unsnapping sometimes they tear the boot .
            Re: soft top boot
            I lost a snap. Then I started using just an occasional dab of WD-40 on a rag. A-OK now.
              Re: soft top boot
              A crayon works well, too.
              ~Jimmy
                Re: soft top boot
                Qtip n vasilene twice a yr
                  Re: soft top boot
                  KY JELLY. Leroy
                  \ \ \ \ \________________________________________
                    Re: soft top boot
                    And...don't forget to use the "tonneau tool" with that KY Jelly!
                    Oh boy... we are having fun now!
                    Originally posted by Leroy View Post
                    KY JELLY. Leroy
                    CVCashmere
                      Re: soft top boot
                      and then along comes Dot...
                      IF you scroll down far enough on my interior page, you will find info on care of snaps & installing the tbird boot:
                      http://www.portholeauthority.com/the...nter.html#boot
                      (and some of those tips were gleaned from previous posts on this site, including how to install the 02 boot. Thanks! TBNers.)
                        Re: soft top boot
                        BE VERY CAREFUL WHEN APPLYING ANY TYPE OF GREASE
                        iT CAN AND WILL BLEED THRU IF APPLIED TO HEAVILY.
                          Re: soft top boot
                          Thanks for all your suggestions. I put Vaseline on the snaps and within a few minute I could un snap them and snap em together again though it was still a bit difficult but not impossible as before. My guess is they will be even easier tomorrow. Really appreciate the 11 responses Tom Tabor
                            Re: soft top boot
                            Tom do a search on boot removal tool and it has a couple of items that make removal easier.It's removing them were we can tear the snaps.
                              Re: soft top boot
                              I use a qtip and vaseline, works great. Put vaseline one every 3-4 times you use the boot, you should not have any more problems.
