What Do You Use To Clean Your Soft Top?
  • What Do You Use To Clean Your Soft Top?
    I've had a lot of convertibles but never had one with a cloth top. I would think they are more difficult to keep clean. So I bought some kind of expensive cleaner and protectant from Thunderbird Concepts. I hope it works and will be worth it. I'd hate to have to buy a new top because I neglected the one I have.
    Re: What Do You Use To Clean Your Soft Top?
    I vacuum the top before I wash it w/a good quality car soap. I let it top air dry and never use a towel on it.
      I run my car through the car wash all Summer and the soft top gets the soap and wax just like the rest of the car. My top is 8 years old and is Black and looks perfect. When it rains the water beads up on it. It's also garage kept and never intentionally driven in the rain and garaged all Winter. Leroy
      \ \ \ \ \__________________________________
        Allen go to this site and get the best recommended products from the very people that make our cloth tops.
        http://www.haartz.com/en/consumer_in...p_cleaning.asp
        You can go wrong with these products and very easy to use.
          I go to the self serve spray wash and use the pre soak spray with soap and rinse 6 years no stains and its the light sand color
          TEXAS THUNDER PLANNING COMMITTEE
            When I first got mine it looked horrible with mildew stains. It is Ash gray so they really showed. After trying every expensive top product sold I reluctantly cleaned with a mild bleach solution and soft brush. The mildew came right of and then I applied a top dressing. That was a year ago and all looks well. Cleans up with car soap and water.
              I use Bradford's solution on mine, both of which are light (one sand, one lt stone). You can find it here:
              http://www.thunderbirdnest.com/forum...65&postcount=3
              Drive like you mean it!!
              ~Elle~
                Ditto!
                  Mike, The product I got from Thunderbird Concepts says on the package "Tested and Endorced by Haartz". Hearing that many just wash their top when they wash the car is good to hear. I just want to do anything I can to keep the top in good shape.
                    Allen, with a black soft top, you have the easiest softtop to keep clean.
                      The owners manual recommends using Motorcraft Detail Wash (part # ZC-3-A) to clean the top. (page 151 in my '03 manual) It is available at your dealer. I use the Detail Wash a few times each year, but mostly just vacuum then wash it with a quality car wash. I treat it with Ragg Topp each spring. After 9 years the top still looks good.
                        Allen, I have gotten the same cleaner & protector from Aaron at TBC and it works great. I have a Red Bird with a Black top. I vac. the top. hose it of when washing the car spot clean areas if needed and then hose it off. I also spray it about every other month with the sealer of water protector that comes in the kit... I looks great.... If it does get in the rain the water beads up on the top... Most of the time I do not drive mine in the rain. If raining I'll drive the Caddy or the truck.. Good luck.. Aaron will take good care of you on your needs from TBC...
