My CD Player no longer working. When I press CD, it says no CD/Error. I still have CD's in the player...any suggestions?
CD Player
Re: CD Player
Evidently a common occurrence. After 6 months of almost constant useage mine did the same as yours.
Many will mention sticking a credit card or another cd in to "pop" the stuck cd out. Didn't work for me. Pull it and ship it to many repair shops (use the search function) or Ford will replace under the ESP for the $100 deductable.Bill Coates-Canfield, Ohio
Re: CD Player
If you're going to pull the unit, this may help, and post 19 may take care of the problem if you can't free the cd with a credit card:
http://www.thunderbirdnest.com/forum...ght=pull+radio
Search old posts, this is a fairly common issue. Good luck, please let us know how this shakes out.Life without passion is no life at all.
Re: CD Player
Try disconnecting the battery for a few minutes. It may cause a reset. This has worked for a couple of people on this site, and it was suggested on one of the repair links here.sigpic
2010 Jaguar XK coupe
1985 Honda Nighhawk "S"
2013 Lexus RX350 - wife's
2013 Mercedes E-350 coupe
Re: CD Player
Make sure you only put commercial CDs or Copied CDs with NO paper labels in the player. The paper labels make the CD too thick (and maybe cause problems with heat).Frank
FEs Tbird
Re: CD Player
http://replacementradios.com/product...roducts_id=141
Looks like $140.00 to repair.
Re: CD Player
Have posted that my cd player has a stuck cd in it. Have got a '02 unit coming from a buddy and bidding on a harness from PIE to get my iphone music to play thru the car.Originally posted by FEsTbird View PostMake sure you only put commercial CDs or Copied CDs with NO paper labels in the player. The paper labels make the CD too thick (and maybe cause problems with heat).
Well lo and behold I'm driving down the road and out pops a cd, an "initializing" message pops up on the screen and the music on the next cd starts playing. Spooky but I feel like a kid at Christmas.
Will not use labeled cds, was there something about thickness of cds. Don't know any thing about these players. Should I leave the empty slot empty? Any other do's or don'ts to keep this player working ? any maintenance that might help.Last edited by wcoates; Feb 9, 2013, 09:17 PM.Bill Coates-Canfield, Ohio
Re: CD Player
In winter, the grease in the changer mechanism (2002) is cold/hard. Do not change CDs until inside of car is warm. Or else have the changer serviced with new lubricant.
Had some close calls in winter but now I make sure the car is warm before changing CDs until I decide to work on the radio/changer.
Originally posted by wcoates View PostHave posted that my cd player has a stuck cd in it. Have got a '02 unit coming from a buddy and and bidding on a harness from PIE to get my iphone music to play thru the car.
Will not use labeled cds, was there something about thickness of cds. Don't know any thing about these players. Should I leave the empty slot empty? Any other do's or don'ts to keep this player working ? any maintenance that might help.2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
Re: CD Player
That would not be a hardened grease problem. It would point to an electrical or other mechanical problem.Originally posted by steelblue5505 View PostAnd oddly enough if the dash gets too hot from being parked in the sun during the hot summer days the same problem happends until the interior cools down a little bit
